I'm spreading the wealth here for those of you who like to fabricate your own stuff. I used 1/8" aluminum, a jigsaw, and a file. Here is a printable blueprint if you wish to make your own! Mine is a '96 so it will fit all years with the same parts! The blueprint should print out to exact size (7cm between subframe mounting points) Enjoy!
EDIT: You might transfer this to cardboard to check for fit.
