Yup, they are compatible, no problems. As an alternative, if you can get Motul RBF (racing brake fluid) Dot4, I'd highly recommend it. It has a higher boiling point than other Dot 4s. The brakes should be bled enough to refill with fresh fluid at a minimum of once a year.
