Hi fellow honda riders!
I need to drop the front of the engine 1-2cm to remove a water hose connection. In all wisdom the upper bolt for the connection is behind the frame
I hope somebody would have experience if I need to remove the throttle bodies to drop the engine?
My plan was to leave the back connection bolt (thru the swing arm) and remove all other frame bolts and gently lower the engine with a hydraulic jack underneath the oil pan.
I have removed the following:
Thanks in advance
-tom
- exhaust manifold
- gas tank
- air filter housing
- air intake on top of the valve cover
- radiator
Thanks in advance
-tom
