The other day I made a clumsy mistake with my battery. I was reconnecting it after charging it when, as I was tightening up the positive terminal, the spanner touched the frame and caused a couple of sparks. The negative was already connected.
I thought I may have blown the main fuse but it all seemed fine.
I went for a long ride down a motorway and when I stopped at some lights, I could smell a strange smell. I checked it when I got home and couldn't find anything wrong.
Monday morning, the starter motor hardly turned. But after a few tries it got faster and it started ok. When I got to work I restarted it and it was fine. Come home time, it didn't want to start again.
I changed the battery for my old one and this morning it fired up fine on the button but when I let go it died again. After a couple of tries it stayed running.
The battery which I took off, which was almost new, was showing 13.5v and was very hot to touch.
I hope all I have done is to short circuit the battery and that I'll be ok with the older one for the time being.
I got out the voltage meter when I got home this evening. And, with the ignition off, it is showing 13.5v at the battery. Engine running it shows roughly the same. However when I revved it to around 5000rpm or more a couple of times it showed 16.5v.
Is this excessive? Am I looking at having to buy a new Regulator/rectifier?
Any help would be greatly appreciated.
Many thanks in advance.
