1 - 12 of 12 Posts
Looking for some insight here. From what has turned up in the searches it seems what I experienced may be perfectly normal however I'd like to get your thoughts on the situation.
I have a deposit on a 03 954 w/ 23,000km on it and the valves were just done at 21,000km. The bike appears to be in absolutely minty fresh condition. The day I placed a deposit on the bike it was -22* celsius out and the owner had attempted to start the bike for me. She fired up right away but it didn't sound like it was properly circulating oil so we shut her down.
Has anyone ever heard the noise the bike makes after sitting in storage and attempting to start in cold temperatures? (thumping clunking type of knocking sound lol) If yes proceed...
I went back yesterday since it was 2* out and she fired up without any issues. The same sound was there but it was very very faint. We let the bike run for about 5 minutes until it got up to temperature where I then ran the bike through the gears and even reved it up a bit. She sounded perfectly soild all except for that one faint noise I am trying to describe. Unfortunately I didn't even think to pull in the clutch to see if it goes away.
I've owned an F4i for 6 years and I may have heard something similar but i'm not sure and I'm not sure if it's just the way the 954 sounds in general.
Any thoughts on the above? Anyone experience anything similar?
Thanks.
Discussion Starter #2
btw, there is 10w40 in the bike and I know it's not rated for those cold temperatures.
I seem to find when my Passat has been sitting for a while, most of the oil usually sinks to the sump. When I start the engine, I sometimes get a metal to metal sound before the oil begins to circulate.
The 954RR are renown for their thin engine cases and as a result do sound a little loud when idling. That could be the noise you are hearing (I get worried when I don't hear it) but if its too loud, I would check it out.
Discussion Starter #4 (Edited)
The bike was stored since November or so and it's now February. I would assume all the oil sunk and got pretty thick due to the cold temperatures. -22* celsius is pretty damn cold and that day it loud enough to realize something was not right. The other day when it was 2* celsius she fired up right away and the sound was no where near as evident as it was the previous time. Like I said, very very faint but I could still hear something ya know and I just don't know if that's they way the bike is suppose to sound. I'm going to check out my buddy's 02 R1 tonight to see if it makes any similar sounds. Unfortunately I don't have access to anyone with a 954.
*edit* I just talked to my brother which is a VW mechanic and he was with me the first time we started the bike. He said the noise the bike made definitely came from the bottom end (case). Now I'm just wondering if the noise I'm hearing is the remains of an issue that occured from starting the bike in the cold or again just how the bike sounds in general. :S
Comparing it to a different make of bike will be pretty useless. The 954RR did have pretty thin engine cases and as a result can sound metallic when initially starting up.
Try starting her up when she hasn't been subjected to harsh temperatures and have a listen.
Discussion Starter #6 (Edited)
^I definitely will try starting it again in warmer temps however if it is normal and from what you're saying, would it start off generally louder and then work it's way down to a more faint type of sound once the bike is warm or would that sound generally disappear all together?
My bike made exactly the same noise when I went to look at it last November. Was a bit chilly then, though not quite -22! It didn't worry me as I knew that these bikes have very thin casings as mentioned before. I did mention it to the Honda Tech. who did my valves clearances and he gave the bike a good going over and said all was OK.
has all been well since? did it start off generally loud and then go very very faint once the bike warmed up?
if the owner is okay with it i'm going to have it brought to a local shop for a quick diagnosis on the dyno.
The noise should disappear fairly quickly once the oil has begun circulating around the engine.
Did the bike make any other knocking noises? When you rev the bike, (once its warmed up), check to see if any other abnormal noises are heard.
Also, to save you a bit of money, why not buy a PC3 and then dyno the bike? Would save you the hassle and money of having to do the dyno all over again.
other than that the bike seems all around solid. surprisingly i didn't even hear the CCT.
well the diagnosis is only going to cost me $40. if all goes well and i decide to get it, it will get certified on the spot. i'll probably look into getting a PC3 later in the summer.
might just be the cold imo
that's exactly what i'm starting to think but for $40 i guess i can't go wrong getting that diagnosis done.
a friend of mine might know someone with a 954. if i can get a hold of him before saturday i may not need to get the bike checked over.
Mine does that. It's that exhaust htev valve. It kinda clanks around in there until the exhaust gets warmed up. It still clanks a bit warmed up but not near as much as when it's cold.
I've never heard a 954 sound near as quite or smooth as an f4i. Those are some smooth running machines. Not as monsterous as the 954 though.
Sounds odd, and the cold doesnt help either.
I duuno, i had a 954 and before the shim / valve clearances were done it was barely a little ticking sound that came from the engine. After the shims were check the bike was fine. Even when starting from cold after a few days it never sounded bad in any way.
The engine was solid with 29k miles on it and still as tight as it was when it came from the crate.
If the bike is making a noise and you aint sure walk away from it, it just aint worth the hassle. Buy yourself am 04-05 model if you cant get the 954.
1 - 12 of 12 Posts
