Anyone care to give me a hand and look up error code 3-4. I get three slow, then four fast blinks...Thanks in advance for any help.
I think 3 slow, 4 fast is 34, which is 'Faulty EGCV and air intake valve servo motor potentio meter voltage'.
Bascially that is the valve that all the cables (from the exhaust valve and the intake flapper) go to. You can unplug it and use an ohm meter to check it. Standard is 5 ohms when you measure the resistance.
Thanks, I'm ordering a new servo motor from Ron Ayers, you just confirmed my suspicions...Thanks again
