i have a 2003 954 cbr rr .....i have a flashin red light with a fi indicator ....the flashes are codes and the manual tells u what they mean......long flashes are tens and short are ones..... i have 3 long flashes and 5 short ............ can any one look this up because i dont have the manual........thanks to any one who can help
Exhaust Gas Control Valve - the one in the exhaust pipe before end can connected by two cables to a servo motor under teh tank/airbox somewhere.
Air intake valve is probably the flapper in the airbox, again controlled by a servo motor on two cables. the servo moter lives under the LH side of the airbox somewhere but I've not seen ever. I removed the flap and left the cables on the servo motor.
the motor is directly below where your left thugh would be when sitting on the bike. It is an odd looking apparatus that looks nothing like a motor. It looks like it has a primer bubble on top of it. you have probably seen it several times and not realized that is what it is.
