1 - 1 of 1 Posts
have for a f4i/929/954: ON THE 929 AND 954 IT THE MOUNT USES THE REAR MOTOR MOUNT, THATS WHY THIS CAGE FITS ALL THREE BIKES
custom tygershark cage. was powdercoated white, now sprayed black, been on the ground a couple of times nothing major. has all hard ware but the all thread. HAS THE springs, rubber, sliders, etc.
looking for 200$ shipped out of it
929:
two lower portion stays, both straight one upper stay, a little bent on right side but mounts up just fine on 929 upper
each lower: 35$, upper 20$
929/954 headlight/ turn signal box: 9/10...... 25$
929/954 rear rotor.....35$ straight as an arrow
929/954 rear dual hb caliper bracket. two stock brackets welded together proffessionally. has both calipers and both have hh brand new pads. 120$ for the bracket and calipers and pads
929/954 rear vortex sprocket....just painted in pic. +9 .........30$ also have a chain to go with it. gold DID chain. 80$
set of 929/954 clipons, little nub is grinded off so you can turn them out, completly straight. 40$
929 sick innovations round bar, about 80% left on it, powdercoated white, scratched up.... 50$
929/954
rearsets, powdercoated dual stage red, comes with foot guards, foot lever, peg holder, and one peg, other one is missing in action. and foot brake resovoir and line
ill take 60$ for each side or 100$ for both...
929 airbox with kn filter 40$
929 wire harness 70$
929 throttle bodies 80$
954
954 throttle bodies 100$
airbox 20$
full wire harness. from the headlights to the tail light. including exhaust servo motor, injector plugs, tipover sensor bypassed
120$
954 ecu
100$
03/04 636
set of forks, completly straight no leaks of any kind. only prob is on the left fork the little metal piece to mount the fender is missing.
130$
03/04 set of front rotors 100$
03/04 rear rotor 40$
80'' hb line...40$
03/04 rear right passenger bracket/ peg for exhaust side.
35$
05/06 rear caliper bracket....25$
03/04 throttle bodies 100$
03/04 wire harness 100$
cbr 1000rr radial master cylinder 100$
i can do the brake line and 1000rr mc and the dual caliper bracket and calipers for 210 shipped as set, cheaper that way.
all these prices are negotiable, need these parts gone.
if you want something call me at 720-490-6307, my paypal is [email protected] if you just want to pay for it. first dibs gets whatever
ill take good offers on all...
1 - 1 of 1 Posts
