i have the same symtems.please excuse the spelling. the bike i got had been sitting for about 3 years has 14k miles on it,there was some gas that dryed up.I cleaned the tank real good, got thefuel pump goin put a new battery and changed oil/filter coolent,and fired right up let it warm up for about 15-20 min .did that for a few days befor rinding it.everything was good, i rode about 4 miles and ran out of gas in the gas station(lucky me) when it died i tryed starting it and didnt start checked the tank emty but i hade at least a gallon and half in there and went down the road and all gone,so put 2 gallons in and started right up went to let off the clutch it stalled,i was able to start it giving it almost full throttle while cranking the motor,then right after i noticed white smoke comming out the exhaust.i had a friend fallow me bak home and he said it smelled like fuel so when i got bak home i drianed about a cup of oil to se if anything was wrong se water coolent idk anything wierd. the oil was very runny and reaked of gas, i checked in the tank and most the fuel was gone,took out the spark plugs and 2 inner plugs wer wet but not fouled acording to a bike shop i took them to to see how much for new,.so i swaped them around to se if problem fallows bad plug, started the bike for a min, then pulled the plugs again and all wer wet, pulled the air box off and looked into throttle body and they all had fuel sitting in them and one was full,i hooked everythingup and held the fuel rail and injectors out to se if they are stuck open i primed the fuel pump a few times and no fuel came from injectors at all but the lines comming from under the throttlebodys and goes to the fuel pressure regulator is sucking in fuel and flooding inside throttlebody,,so now im stuck,..im not sure if fuel gets sucked from fuel preesure reg. to the lines goin to throttlebody.. can anyone help????????????????????? this is my first bike and dieing to ride!>, Email me supranation@yahoo.com
