Issue I'm having with my 2004 1000rr is when I give it full throttle in any gear but first at the higher rpm range the tachometer drops to zero and the red light for oil/coolant comes on. It decelerates the engine but when given throttle there's no response and holding in the clutch or putting it in nutruel it dies. Put it on a stand and went through the gears it will run fine. Also seems to run fine in nutruel. It only does it on the road. Can't seem to figure it out any help would be great.
