Can someone wit a service manual tell me what it means when I'm getting 1 flash over and over again with 2 seconds in between them
thanks
thanks
:welcome: to the .org! Great place for Firebladers :thumb:
I've got a manual at work, might pick it up tomorrow..
The error codes are: long flash=10 short flash=1 You must count the number of short/long flashes to be able to determine the cause..
If the bike is yours, you should consider buying a manual. I bought mine here repairmanual.net
If it's 1 flash (not a long flash), the manual says it is something electrically wrong with the map sensor (compared to 2 blinks which is vacuum problem with the map sensor.
