1 - 10 of 10 Posts
I have had this 15t Sprocket for 7 mo.s and not put it on cuz I thought is was going to be pressed in place.
I was wrong, 15 min tops to install!
Now I need the torque spec for the 14mm bolt that holds it on.
I did a search and came up with notta...
And wow, Nice little extra get up and go!
My speedo is off 6-7% based on measurements of 10ml stretches of hway markers for 50 mls straight.
I believe that 6-7% should stay consistant w/any speed, Since I measured it in fluctuating(sp) holiday traffic and still had the same results 5x over.
Just off the top of my head I think it's 40. Don't forget some Loctite. Do you have Ahlman's Recalibrator?
I gave up on the 15t front, I'll go up in teeth on the rear sprocket when I do my next gear change. (had to be careful wording that statement)
SuperDave : Just off the top of my head I think it's 40.  Don't forget some Loctite.  Do you have Ahlman's Recalibrator?
I didnt have any LT available yesterday, so I have to apply some today.
40ft lbs sounds about right for the tightness that it broke from.
Is the name of the bolt that holds it called a:
'drive sprocket special bolt'? If it is,the proper torque setting is 40lbf*ft
I also dropped a tooth a few months ago because the majority of my riding is in the city. Man, what a difference
Inferno : Is the name of the bolt that holds it called a:
Thats most likely its name, THX
Ditto on the city riding!
1 - 10 of 10 Posts
