I have three 92 RR and one has a blown motor that I'm looking to retromod.
What engine can I got into the frame. Would a blackbird motor fit?
The simple answer is no, it wont.
The difficult answer is yes.
There is a guy here who has put an XX motor in his 900RR however it took some extreme modifications.
There is also a person here who has put an RR4 (2004 1000RR motor) in their 900RR frame, again, with substantial modification.
Nothing really. The issue comes with the cross member that holds the coils. It gets in the way of the fuel rail and air-box of the newer, larger engines. The engine mounts also need significant re-working and in come cases require removal and adding of frame material.
The 929 and 954 motors can go in, with less work, but the pivot-less frame design of the engine cases can make it difficult too.
I would say you are just better off going with a rebuilt 900RR engine, unless you want to rise to the challenge.
