Hello All,
I just installed a Full Hindle Exhaust and PCIII. After removing the flapper in the air box it hesitates in lower RPM. Does anyone have a Map for a CBR 929RR with the Flapper removed?.
Hello All,
Do you mean that it was fine with the full system until you removed the flapper?
Discussion Starter · #4 ·
Blade racer I did not explain the problem correctly, I had removed the flapper in the air box and cut my cable too(<-----Dumb ass). When i installed my full hindle exhaust and PCIII. I found my bike stumbles at low RPM. I put the flapper back into the air box and connected the cable which operates it. Now the hesitation is a lil better but it still does it at low RPM. Is this normal because the bike does not have the exhaust servo. Or will i need to tinker around with the AFR.
I would think it's a fairly normal result of the full system but optimising the fuel map will minimise any problems.
