1 - 14 of 14 Posts
So I found a used power commander locally for $100. Guy bought the bike a year ago and it was already on the bike.
Sounds good to me.....but...
What should I look for physically?
What should be included?
What type of software do I need?
How do I make sure I am getting a good deal?
And...if I do buy is it literally as easy as plugging it in and downloading the correct map? No dyno's or bringing it somewhere to have it programmed?? Just plug it in and pick a map??
Physically they can look really shitty but still work fine so visual inspection is meaningless.
I don't think there's anything included although a cable would be nice if you don't already have one. It's a standard USB or serial cable.
If it's a serial model I think you need the serial software but it's available for download.
Only way to know is to test it on a bike to see if it works.
Yes. They're all serials except the USB and I guess that new model they have now.
still worth it even if it is the serial model... it's not like it uses get used up.. it's as good any day as it is from day one..
Not quite.
Early PC's have a reputation for failing.
Not a problem if you buy new as they'll replace it but a secondhand one that fails you'd have to fix yourself.
All electonic parts have lives limited by factors like heat, vibration and moisture (or a Honda part number).
hahaha I like that last one. I need a steering bearing, front fork seals and a rear tire. people have been screaming at me telling me I need a steering dampener too. So I think I am going to not be impulsive and get those things taken care of first. Ive only had this bike down the road a few times and have already experienced the tank slap so Im going to get one of those before I concern myself with how much power im putting to the road.
one at a time if thats how you gotta do it. a new pc3 is only around 270 shipped in most cases. not a ton of money. i would go with the damper first expect to spend between 200-500 for a damper depending on new or used. just remember rome wasnt built in a day and before you know it...
basically dont waste too much time looking to get all this done for peanuts, it wont happen. and if a price on a used part seems to good to be true dont buy it. electronics are not something i like to buy used
well i disagree and this is strictly my opinion.
i dont see anything wrong with buying used as long as it works fine and i say this simply because, how many of us bought our wonderful 929, 954 ect ect brand new off the show room floor?
i didnt, i got it used and cheap and it runs like a champ, i have about $4k invested in my 929 and i say invested because that is the total of parts and the motorcycle $4k so if i was to sell it i wont take a loss and might even make a profit and this is what i have for $4k
modifications: Custom ram-air intake BMC filter Factory Pro Velocity stacks Power Commander 3R Full Scorpion Exhaust PPM lowering link Scotts Steering Stabilizer Heli Bar Clip-Ons White Painted Wheels Custom BLK/WHT Seat Covers 15/45 520 Vortex Sprockets Lockhart & Phillips Frame Sliders Lockhart & Phillips Dark Smoke Windscreen VS3 Rear View Camera & Monitor Mirror Block-Offs Barend Mirrors Custom Billet Rear-Sets with CBR 1100XX Shifter(reverse shift Pattern) L.E.D. Intergrated Taillight 200 Rear Tire
most of which i i either got used or really cheap
like the pc3
the exhaust (which was new but never installed)
heli bars
velocity stacks
shift lever
stearing damper
i recommend that if its a saftey item like brakes ,tires and or contols, i recommend new:rotfl:
If you are interested i have a bridgestone bt014 at a friends shop in bangor you can have if you want about 3/4 tread left, I didnt like how it handled. i put a set of metzler M3's on and stayed with the metzlers since, it is a 190 rear. you will have to pick it up.
I doubt anybody would disagree with this.
The problem with electronic parts is that they have a limited life and give up with little if any warning. If you're getting it cheap then sure, why not try it but you have to expect it's not likely to last long. It may "work fine" for a week, a month or maybe even a year.
I would not recommend spending much on secondhand stators, regulators, servo motors, PC's and such that are known to have very limited life anyway.
1 - 14 of 14 Posts
