Found the gearbox issue
906 views 5 replies 4 participants last post by  Duncan893
#1 ·
Hi guys found the issue with my jammed gearbox see attached picture I've removed the gear change mechanism and removed the six bolts on the plate behind the clutch but the gearbox still wont come out of the cases I've removed chunks of gear teeth from the sump as well its stuck in gear is this why the cassette wont come out ??
106595
See less See more
1
#2 ·
Chunks of gear teeth should answer your question. Something is really mashed up in there. Requires a complete removal, inspection and replacement of necessary gears.
Good that you've found the problem, which must be some sort of relief. Now you have the expense.
Former owner realised that he'd trashed the box, and that MIGHT explain that he gave up paying for it and the finance company repossessed. With help from some of the more mechanically-minded guys on here, I am positive you can get it up and running in very short time.
