I recently tried to do a sprocket change on my 1995 900rr. When I removed the cover of the front sprocket, the head of the bolt was stripped. Is there any easy way of getting the bolt off? heat, grinder,etc.
Could I used a grinder and cut the head off and still have enough bolt underneath to work with?
any tools that may help?
Any input would be helpful,
Thanks
yeah cut it off mate u will find one there is no tension on the bolt u can probaby undo it with some pliers
File it down a bit so you have two flat surfaces - it'll make it a bit easier. Assuming there's space to do it (can't recall if the bolts are recessed a bit inside the cover or not)?
Just get yourself a 5-6mm sharp drill bit and drill off the head..U wont be able to grind 2 flats on it no room..Its easy mate just make u have a decent drill and run it at highish speed. The bolts are soft so cut easily
