so im kinda new to motorcycles... i have an 06 cbr 600 f4i.
i recently had to get new tires.
when i took the wheels off and took them to my local cyclegear they took out the spacers from the front wheel. the spacers are not the same size, one is about half inch wider then the other one.
my question is: which goes on what side? or does it even matter?
it dose matter because when installing the front wheel the routers wont go in right one will be very hard and slow the wheel down if that happens then switch the spacers if not and wheel spins freely the you have put them in right :)
so i cant tell if there in right till i put it all together...well that sux...
thx for the info..
yeah cant really tell right off the back its trial and error till you can figure it out then you can probably mark them R-right and L-left to make it easy for the next time you have to work in the front end department that's what i did makes it very easy to remember :)
