Just added to eBay, take a look........... Can always cancel eBay, if anyone is interested.
edit: looking for around $7,100 obo
Off eBay and bumping for one last shot. Here is more info about this trailer.
Price has dropped too: Asking $6,200 obo.......
Chariot Trailer Cycle Shuttle 16 Tandem EXTRAS 1998
At Last a "Big Bike" Cycle Carrier designed for 2 Full Dress Motorcycles or several "Sport Bikes" like Sportsters, Ducatis, BMWs or Ninjas. The tandem axle Cycle Shuttle 16 is designed to be easy for one person to load and unload. Chariot Enclosed Trailers feature a standard washout interior gel-coat Spackle w/nonskid floor and door and a white gel-coat exterior. Molded fiberglass uni-body construction with foam core walls and plywood core floor coated with fiberglass are not only strong, but offer low maintenance. The roof capacity is approx. 300 lbs. The standard Eyebolts are positioned for easy tie down of most any cargo. The back door lowers and becomes a Ride-In load ramp for easy loading, and for security the door features a heavy duty rear door cam lock with automotive rubber tube door gasket and extra heavy duty all aluminum door hinges. With the standard roller tongue jack you can easily maneuver your trailer and cargo by hand like a five wheel cart. The Cycle Shuttle 16 also comes with a 12-volt interior light standard.
Standard Features:
• Rear Door Loading Ramp
• Roller Tongue Jack with Rubber Wheel
• 2" Coupler Matched to the Height of Your Hitch
• Electro-Coated 14” Wheels and Goodyear Tires
• 2 Dexter Torflex "E-Z Lube Axles"
• Tapered Automotive Roller Bearings
• Forged Eyebolts for Tie Down (12 Standard)
• Electric Brakes 10” 3500lb Capacity Std.
• Brake Away Brake Kit
• Rear Stabilizer Jacks
Specifications:
• Dual Bike Carrier (2 Full Dressers)
• Tandem Axle, E-Z Lube Hubs
• Base Weight: 1250 lbs Tongue Weight: 90 lbs
• Body Load Capacity: 3650 lbs
• Axle Capacity: 7000 lbs (Tandem)
• Ball Height 17”
• Dual Brakes - Electric 10” Both Axles
• Brake Capacity 7000 lbs
ORIGINAL OWNER.
OWNER ADDED EXTRAS LISTED BELOW. (Have ALL Paperwork)
INTERIOR BUILD OUT:
Non-Skid Floor Tiles (Interior and on Ramp)
Diamond Plate Trim
**ALL CABINETS COVERED WITH SPEAKER CARPET**
Rear Cabinets, Left and Right Sides
-Large Enough For Jackets
Front Shelf and Cubbie Hole
Wheel Chock Grommets
EXTRA Interior Light Module (Now has 2 Fluorescent fixtures)
E-Track Tie Down Rails, with Connectors
Extra Roof Vent (Trailer has Two Now, one Pulls in, other is Exhaust)
Alarm on Trailer
-Includes new locks on Trailer Door (Two Alarm Clickers)
Chrome Wheel Caps
Exterior Striping
Fire Extinguisher
2 Batteries Located Inside Trailer (With Trickle Charger)
Rally 2 1/4-Ton Floor Jack
Emergency Road Kit
Front Tongue Box:
Spare Tire
Cleaning Supplies
VIN: 1C9-C162D-X-WF158-200
Listed Weight: 1,250 Lbs.
Body: Fiberglass
Dimensions: (OVERALL)
Length - 17 Feet 5 Inches
Width - 8 Feet Overall Width
Height - 7 Feet 10 Inches
Interior:
Length - 13 Feet
Width - 7 Feet (6 Feet within wheel wells and built in cabinets)
Height - 6 Feet 2 Inches
Rear Door:
Width - 4 Feet 10 Inches
Height - 6 Feet
