1 - 18 of 18 Posts
I could really use your help here. I have 2000 929 that ran fine up until about a month ago. I started trying to just give her a good pick me up to get ready for the season. I changed the plugs and oil and decided to take the throttle bodies off and clean them out real good they were a lil gunked up so i did all of that, put it back together and the fuel pump wouldnt prime when you turn the key. I checked the things it says to in the manual as far as i can tell, BAS is good, starter relay good, fuel cut relay good, fuel pump works when hard wired, cant find any open loops on anything. I have noticed tho that the power to the fuel reserve connector is very weak barely enough to light the tester when the key is on. Thanks for all of your help!
When you say "gunked up" do you mean the dark coating on the edge of the throttle plates?
Is the battery fully charged?
yeah i mean the black build up around the plates/butterflies, and yes the battery is fully charged. The battery is within specs according to the manual. The only code is the light that stays on which the manual says is Short circuit in service check connector wire or Faulty ECM, but the symptoms are that the engine would run normally. So i am at a stand still with it.
Thanks again.
Thanks again.
The throttle plates have a coating on them that can easily be mistaken for crud, that's why they have the warning in the manual about cleaning the throttle bodies carefully. I doubt removing the coating is likely to have any noticeable effect though.
Have you checked that the kill switch is functioning?
yeah the kill switch is functioning properly also. I'm pretty sure it wasn't any kind of coating, but i guess ive been wrong before and i didnt take a wire brush to them or anything just q-tips and throttle body cleaner. im sure your right tho i dont think that would effect pump prime. i ordered another fuel pump just in case.
thanks
thanks
If the pump and relay are working then I would be looking at the kill switches.
I checked it according to the manual, but i will just order another one and see if that works so i can be certain. I have also been trying to find another ecm and wiring harness to see if those might be the problem, but the only one i can find is a california model ecm and ive read that some people have tried them and they dont work so i dont want to buy it and still not eliminate that possibility. I really appreciate all your help.
also another reason i dont think it is the kill switch is because if i put gas or use starting fluid the bike fires right up, and will rev (until its out of fuel of course). Spent the day going though the wire harness and all seems to be good, no breaks or loose connections. Just really damn confused.
Have you checked the ground leads coming from the fuel pump? I've seen an issue a couple of times where the pump isn't being grounded properly, thus not working.
Im not sure what you mean exactly by the ground leads, but i did go out and try to figure it out. If you mean the wiring coming from the pump that make up the connection for the fuel reserve connector then yes i've checked those and if you mean something else then please let me know. thanks.
Discussion Starter #13
alright guys got it figured out. I had bought some new relays from honda last week and tried them and still had the same problem. So tonight as im messing around with it i plug the old turn signal relay (out of the original subharness) into the fuel cut relay connector, hit the key and fired right up, was running rich as hell, but im sure that was because there is nothing else hooked up right now. The only thing on it is the fuel tank. With that said i'm feeling pretty retarded for going through all of this and it being something so simple. I now have lots of extra relays (that are probably toast since they didnt work), an extra front sub harness and fuel pump for the next time. Thanks for all of your help and sorry to waste your time, you have been great.
Great result :)
If you haven't already I would suggest you confirm the fuel pressure regulator is not leaking. That makes the engine run very rich.
It's not a waste of time if the problem is fixed :D
Discussion Starter #17
well i checked the FPR and it was good. it only ran rich for that minute that i had started it, but the problem im now running into is that whenever i crank back on the throttle it cuts out and if i dont release immediately will die. it idles fine, no smoke, fresh plugs, revs fine if only pull back at about 1/4 of the way on the throttle. everything is good besides that. i've been trying to fix that issue since my last post and havent gotten anywhere. OH, also put the fuel pump and fuel filter that i had ordered in too. so the filter is good (acts like filter is clogged so i thought). thanks
1 - 18 of 18 Posts
