1 - 1 of 1 Posts
So long story short I was riding my 929 and while I was turrnig to park the bike cut off. Found the ignition switch fuse blew, replaced it then it would crank but not run. Haven't messed with the bike for bout 4 months till today. Realized the started button is messed up, cause the only way I can get it to crank is jumping the starter button with a paper clip. Hotwiring the tank will turn it on. The fuel pump relay I believe gets no power. All other fuses are good. So where should I start to look again? I've checked most grounds and cleaned em. I'm so lost. :(
1 - 1 of 1 Posts
