Well i figured it out by doing a volt test and just tracing wires. I turned the key on and listened for the relay to click at the same time i was measuring the volts going to each wire, which ever wire went from 0-12 volts and back to 0 when the second relay clicked was the power wire. On the fuel pump you have three wires yellow/red, black/white/ and red/black. On the wiring harness you have three also Green , Brown, and Brown and black. they hook up Green=Black/white (ground wires) , Brown=Yellow,red (power wire for fuel pump), and Brown/black=red/black (low fuel light). ;-) Happy Riding!!
