Alright I Got a spark to my spark plugs and everything wants to run fine except for the fuel pump. I took the rear cap off of the pump and it sparks fine for a little while but after about 15-20 secs you can see that it seems to break connection and after another 10 seconds the pump seems to just stop as if it has lost a connection somewhere. I don't know if they are suppose to run constantly or if they are suppose to stop after a while. In the picture it seems to be broken or worn down cause it seems to be slanted at an angle that allows it to shift to the right a little and parted into two. I don't know if it is suppose to do it or not. Is the pump suppose to cut off after a few seconds? I have a feeling what the answer is but just asking anyways.
