will a 95 gauge cluster work on a 93 900rr? i am new to motorcycles just bought 93 00rr but need some work i would give gr8 thanks for any help?
G'day. It will work, but not without mods. To get it to work, you'll need:
1 x 95-97 900RR gauge stay/fairing bracket
1 x 95-97 900RR speed sender and mount (goes on front sprocket cover).
You need to remove your cable driven speedo gear from the front wheel - the 95-97 speedo is electronic. Then you fit the 900RR speed sender with the mount. This speedo gear replaces your sprocket cover on your bike. You need to run the speed sender wire to the plug on the 95-97 gauges because the 93 wiring harness didn't have provision for the speed sender wiring. You'll probably also have to splice the 95-97 speedo wires ito your harness as I'm pretty sure the plugs were different from the 93-94 models.
You can get all the parts you need from Ron Ayers Motorsports - Motorycle, ATV, Jet Ski and Generators Parts and Accessories or ZANOTTI MOTOR CO. INC, Butler, PA 16001 - Motorcycle, ATV, Trikes, Golf Cars.
Cheers, Simon
It's an easy job to do.
