Hi guys I've found a replacement gearbox for my 05 blade but it's from an 07 it's still a cassette type so will it fit didnt know if there was any difference in shaft diameters ect dont want to go spending money on something that wont fit the engines are still the same code SC57
Cheers
Dont think they changed the gearbox between 04-07 , though some part numbers have changed, check with Fowlers UK, and David Silver UK, they are pretty good with customer services
I looked at the part numbers and they are different the info I got was you have to use the 07 clutch the 04-05 has a smaller shaft so it's not compatible with the 07 unit
Thanks for the reply
