1 - 11 of 11 Posts
I am getting ready to redo the network since I now have G in wireless. Well my Macs have 10/100/1000 cards so I was considering replacing my 4port 10/100/B router with either:
1 a gigabit switch and a cheap G base station
2 a 10/100/g router
Any inputs? Does anyone have gigabit?
The network is 2 macs, a printer, and a pc (10/100 now) with a G based laptop and soon an airport express for streamed music to the stereo.
Thanks
are you running all your computers through one internet connection? my cable company once sent us a letter that we either needed to purchase multiple accounts or buy a router. I only had a switch so it came up with more than one IP address.
Already running the router and only have one address available so need a router.
2 a 10/100/g router
Thanks
Dont have it but for me its a waste. I know that you run alot of servers and machines so maybe its worth the $$ to get the speeds you need/want
Actually I could get by without but the prices are getting decent and I need an upgrade to get G on wireless soooo.... :devil:
GBE is really only useful if your end-2-end systems involved in the transport of your data will support "jumbo" frames. These frames, ( larger than 1500 and up to and in some cases beyond 9k bytes) allow for the utilization of the GBE media to be achieved by as few as individual systems and also allow for less CPU overhead when transmitting larger files such as video. (Since there are less frames/packets, there is also less protocol overhead so more payload can be put in the pipe....)
I could adjust things on the Macs and the 'doz machine is only 10/100. Of course the only reason for the kick would be geekness and maybe VNC. I have a new Airport Express and think I will be streaming from a desktop and controlling from the latop via VNC.
Any experience with Belken anyone? Unlike most it supports Macs (on box so it is official vs it works with) and even supports Appletalk which is sometimes spotty on other routers.
EDIT:
:thumbd: no way will a Belkin EVER be in my house. This is below slimy and even if they removed it still shows the nature of business
Belkin spam via YOUR router
For the Wireless gear check out the Wi-Fi Alliance Certified list and work out which are the possibilities then work from there.
http://www.wi-fi.org/OpenSection/certified_products.asp?TID=2
I went for the Dlink AirPlusG+ DWL-2000AP+ about 9 months ago but there is probably something better out there by now. You can probably get a router/wireless access point/gigabit switch in one unit now.....
http://www.dlink.com.au/Default.aspx?ArticleID=138
As for the Gigabit Ethernet, I've got another Dlink switch with 2 gigabit ports and 8 10/100 at one of the sites at work, and I really don't see that much of a difference (even though the switches backbone supports the full bandwidth load). Unless you are pumping data all over the place then it might be worth it. But I doubt it would be for a home network especially considering the price of a gigabit switch with a backbone that has bandwidth to support all ports going full speed at the same time. :idunno:
EDIT: Also sounds like you are going to mainly use the 802.11g network from now on so that 54Mb bandwidth isn't going to scratch gigabit and 100Mb ethernet will have room as well.
Sounds like that xmas bonus has gone to your head a bit. :D
The mainframe networkers agree here. 1000 is way overkill. In addition to the G wireless I have desktop and they will soon be setup to network render with Carrara :) However I am thinking either a Netgear WGR614 (have b version and like it) or a Linksys WRT54G The accelerated stuff is not worth anything since I need standard G (Apple Airport Extreme)
FYI...I reccomend CAT6 cable for all your nodes if you go Gig... :hmm:
:nod: Stick to the standards.
:nod: but definately don't get anything less than Cat5e
1 - 11 of 11 Posts
