hi guys! need a bit of help with my cbr 929! i did a bit of work on it about 3 weeks ago put it back together went to start it and found out the fuel pump was not priming! so i started to look for the problem and found out that the fuel pump relay is not clicking! when i take off the relay the 2 black/white wires have battery power the brown/black has 4.3volts for 4 seconds then gose to 0volts the brown going to the pump has no power and when i put in the relay im getting battery power in 3 ports nothink in the brown going to the pump and no click. thanks in advance
