· Registered
Hello everyone.. I've been riding since 1988 but the SC50 I picked up last weekend is my first Honda in over 30 years. (92 CBR600f2)..
Unfortunately I've got to do a bit of work before she's road or track worthy.. most notably rebuilding the forks... Previous owner changed the fork seals and I'm not sure whats going on with it now but it feels all kinda of funky. Almost like there's no fork oil in the tubes. As soon as I procure a triple tree stand I'll be ripping it apart to see what's going on. Looking forward to picking everyone's brain for info. I've mostly been a Kawi guy so this is fairly new territory for me.
Tire Wheel Land vehicle Fuel tank Vehicle
· Registered
Welcome to the forum and back to team Honda! I am pretty familiar with the forks, just rebuilt mine again last spring. If you have any questions along the way feel free to ask! You might check the clickers;
The "standard" settings are :
Front Preload - 7 turns out
Front Compression - 2.0 turns out
Front Rebound - 2.0 turns out
Rear Preload 4th Notch
Rear Compression - 2.0 turns out
Rear Rebound - 2.0 turns out
Of course my 200lb ass has the preload wound all the way in and a few washer added to the cartridge to help too. :)
One of the first things I do when I get a new to me bike is a full fluid exchange, including the fork oil.
The 954 takes some time to gel with, but it does reward you once you have.
· Registered
Discussion Starter · #3 ·
Appreciate it... Unfortunately my tool selection isn't what it once was... Luckily there's a world renowned suspension tuner about 20 minutes from me... Gonna run me about 350 for the fork service. While I'd rather spend that towards new gear, I'd rather she ride right first... And I'll just get a scorpion helmet instead of a shoei or arai
· Registered
Right on! Like you, I am lucky in that regard as well. I have an older friend from the UK that is our local suspension guru. He is a wizard in the black art of suspension tuning that spent his entire life abroad working professionally for some very high profile racing teams. What's easy for him and his experience completely baffles me. I used him for fork rebuilds for years before learning to tackle the job myself. I still get him on the clickers because his knowledge and experience far surpasses my own. He would charge me $200 for a rebuild if I brought him all the parts/fluids needed. So, $350 to let someone who can do it well sounds pretty fair to me. Plus, the piece of mind and simple practical benefit of having the suspension setup correctly is a huge part of a well riding bike. I spent a month trying to get right what he does in ten minutes on the tune. Its worth every penny!
· Registered
Discussion Starter · #5 ·
I'm just hoping it'll just be that and not need all new internals
· Registered
350 should get you new seals, bushings and oil. The parts are fairly cheap. Bushings can usually go a few rebuilds without needing replaced. I'm sure they will inspect them and replace if they need it. I'm also sure the 350 quote includes all that.
