1 - 20 of 399 Posts
abtech said:
The Grattan info thread is locked to keep it short and to the point, so please place any questions regarding the event in this thread.
Thanks!
It looks like I'm going to fall into the 'other brand' category. The Honda is experiencing a wierd shutter under hard braking. :idunno:
So, I'd like to bring my R6 for 2 days if it's okay with the org.members. I'll stay in touch.
I'm certain the Honda can be fixed between now and June. Have you checked to make certain the rotors are true?
I changed the pads, front wheel bearings and replaced and bled the brake fluid. That helped quite a bit...but the front shutter is still there when you down hard on the front lever. Maybe there is a slight warp.
I'll pull the rotors have them checked out. Tks for the advise.
Maybe a dumb question, but have you changed the tire since it started?
Here's a dumb ?...Is it OK to go ahead and pay the full amount now, or do you want just the deposit and the rest later? :confused:
You can pay the full amount now. Just make certain you mention this fact in the email you send me.
Got a question related to slowpoke's: Can we pay the deposit now and send in the balance to the same address a few weeks prior to the event, instead of paying the balance at the track?
That will work fine, but please mark the second check as "Payment in full" when you send it so we can keep track of all this . . .
Okeydokey! Thanks for the quick response! Looks like I'll be check-writing tonight! Woohoo!!!!!
Administrator
Thanks abtech for getting all the details hammered out
(been away from the .org for a few days). It looks like this Grattan event is going to be even better than the last! I'll be sending in my $$ for all three days shortly. Can't wait... :thumb: :D
I noticed the problem shortly after the pads were replaced and lines bled. The tires are new (Avon Azaros) and balanced. I don't think the problem is balancing because there is no unusual vibration or head shake at low or high speed. The shutter only appears under hard braking.
Initially I ruled out a warped rotor simply because you'd expect to feel vibration under all riding conditions. I'm leaning more to a caliper/pod issue. By the way...its a VFR with linked brakes.
Abtech ,The 929 is now a street bike. The Suzuki is my race bike. :hmm: Can I sign up now, or do i have to wait. I asked you this before but I didn't understand your reply. :idunno: For give me, I getting old!!!!!
Discussion Starter #17 (Edited)
OK, I only seems fair that Honda riders get first crack at filling the original 25 required slots. Once we have 25 Honda riders or after January 31st (whichever comes first), all .org members are eligible until we hit 40 riders per day.
So you're telling me to buy the 600RR instead of the SV650? :p
Thanks Abtech.
1 - 20 of 399 Posts
