Hello
I need your help to elucidate the problem appeared recently in the H.I.S.S. system for a 929 CBR `00.
I changed some plugs in the electric and therefore no longer light up for the HISS bulb (near the fuel bulb).
We have some possibilities but do not know how to start
1) General button (On / Off General) not working properly (i clean the contacts , i test and it is ok from the button to the red plug).
2) Electrical alimentation for Hiss but I have no idea where I look, I will consult tomorrow electrical diagram
3) It is possible that due to tilt sensor Hiss was no longer start?
The petrol pump indicates that no gasoline and the tank is given below, the pump is connected to the corresponding socket (there is a possibility to work only when the pump is attached to the tank and the negative cable to be picked by mass container frame?)
:idunno:
:huh:
:idunno:
