im having a hard time starting the bike when its cold take about 20 minute of cranking until it reach 160 degree then everything is ok and after that everything is cool until i shift 5 th gear the motor stop every time....... carb problem ???? sorry im french be easy thanks guys
Possibly carbs, most of the time they just need disassembled and cleaned really good. Troubleshooting sucks so I feel your pain. Get a manual and start checkin...
hey hey we found the problem ;-) now let try to explain that .... we undo the carbs on the bike 2 screw were f*ck so the carb #3 and # 4 were not screwed to the cylinder and i had a air leak we clean the carb anyway and everyting will be back togeter on june 24 sunday test drive tomorow so does the update thanks guys hope you understand everything it suck to be so bad when it come to english lolll
the frenchman
