Whats the difference between the Hass elim and running with a open (locked) Htev valve?
Sirkbac said:.
Firebladder.....is that when it burns when you pee?
No, if you removed the valve from the HTEV you'd have a pretty turbulant air path now and most likely would cause some power loss.Brian929RR said:Is there a way to leave all the cables hooked up and just remove the baffles in the HTEV valve? You know, let the servos still work, they just won have anything to turn.
DavidGS said:Solution: Buy the Eliminator and be done with it. Takes just a few minutes to install and is fairly affordable - unless you're broke like me. As soon as I can afford one, I'm getting it.
