1 - 10 of 10 Posts
i suspect my head bearings need to b replaced but im not sure. i dont have any problems steering left or right but i do have a cracking sound every time the bike hits a :idunno: bump. any thoughts?
Whats the mileage, do you do many wheelies or track days ?
you need to get the front wheel off the ground , then move from left to right slowly , feeling for any notch or stickyness , then hold the forks and pull backwards and forwards feeling for any movement atall , there should be none,
Depending on your mileage , the bearings may just need a re-grease and a re-tension , you will need a special socket for the bearing nut to torque it down
mileage is 34K, no wheelies no track days. im going to try puting the wheel off the graound as soon as the weather permits. where can i get the bearing nut from? dealer?
My 929 bearings were notchy at 12k mi. i recommend you replace the stock ball bearings with tapered roller bearings as they will last much longer. I noticed reduced steering effort with roller bearing. All-Balls sells a roller kit for like $30-$40, kit includes dust seals. You'll probably wreck the lower seal getting the lower bearing race off the steering stem. Or, you could purchase from a bearing vendor and save a few bucks, if you know the dimensions or bearing mfg p/n. if you want, I could get bearing mfg p/n from my old ball bearing set that bearing vendor could find the equivalent size in roller type. Or maybe do a search, p/n could be on this forum, other Honda forum, or the WERA forum. ...alex
thanks 2bit, i already have the bearings but the lack of founds keep me from replacing them, shop wants 300 bucks to do it.
Do them yourself.
Pretty simple and only takes a couple of hours.
I've never used anything special.
Getting the lower race off the stem is the hardest part of the job.
1 - 10 of 10 Posts
