I have a 2001 Honda 929rr. I have noticed the front end is off. With the front tire strait the triple tree is about 4 degrees to the right. How do I get it back in the center as it should be, so the handle bars/tree is strait? It’s not a big deal the bike handles fine but it’s kind of like the steering wheel in your car being a quarter turn from where it should be. I guess I’m anal but it bugs me.
Ummm you should be anal about this! Are you sure the forks are not bent, or even the front axle isn't tweaked? My 1993 900rr had a bent front axle shaft and caused the same thang to happen, easy check is to take the axle out and roll it on the fat width side of a 2by4. Also can loosen the bolts to the lower triple tree and have a buddy hold the tire while you turn the handles to the desired location. Just make sure those forks arn't buggerd.
Discussion Starter · #4 ·
Thanks, I have checked every thing. Nothing seams to be bent. Axle is good. Tubs are good. I was thinking of loseing every thing up and see if I can straiten it but it just does not look like that would do any good.
