Anyone know the color code for the paint on the frame of the 2002 954. I got a small scratch I want to touch up. I see it is not just a solid color but it has sparkles in it. I thought about polishing but that would be a lot of work and the scratch is pretty small.
Does anyone have any tips on putting it on. I do not want it to be noticable. Is there one way better then another.
Once you touch it up if you look close you will still see it
only way to make it not noticable is to spray paint it
Dont know if it will work for the frame but i know with body work you can wet sand with 2000 or 2500 grit sandpaper, then polish, then scratch-X sealent. Should be unnoticable after that....
I thought that was anodized though???
