Dear guys...
I got problem with my bike, it's hard to get first gear, second and third. When i push the pedal gear for 1'st gear is always hearing "crack...crack..crack...". It's normaly? if not what should i do?.... :idunno:
i would check the clutch cable to see if its pulling the clutch and if it is i would take your bike to a shop and have them check the clutch
Dear guys...
Sounds like clutch adjustment.
4th, 5th and 6th are fine though?
I was set clutch adjusment in number 5....but the problem is still. And for 4th, 5th and 6th gear ..truly i'm not ever to try to used because is imposible for me to try it in the city.....:O.
The lever adjustement is just for altering the lever span.
I forgot you have an hydraulic clutch.
In which case I would suggest bleeding the air out of the system.
If the fluid hasn't been replaced in tha last two years, replace it.
