I just got an 01 RC51 from my brother and the gauges don't work, I've checked the fuses they're fine. My brother layed the bike down and they quit working, how could I trouble shoot it. Also where is a good place to find parts, I need a outer clutch cover and radiator on other side and plastics can some one help plz.
Disconnect the cluster from the main harness, then take 2 jumper wires between your 12V bike battery and try several different slots on the back of the cluster.
You can't damage anything this way so don't be shy poking around with the wires.
Hopefully you'll get some lights!
Check your fuses too, I had that trouble on my 954rr. found a popped fuse, replaced it, turned it on, fuse popped as soon as I turned the key. That told me there was a grounding issue, luckily it was easy to find, it was in the tail. Anywho, check and see if any of your fuses are popped. Thats where I'd start. Hope this helps. good luck,
