1 - 12 of 12 Posts
I need help, my motorcycle doesnt start and I dont know how to read the malfunction lights and blinks. When I turn the switch on, the fuel pump activates and the malfunction lights blinks one time and stay on. Im desesparate, please someone watch the video and suggest me something, I will be very gratefull.
Have you checked the battery?
Of course man, the starter is doing fine, the problem I believe is in the FI system because it appears and the malfunction lights stays and blink once. But thanks anyway for the suggestion.
Make sure the kickstand is down to get accurate MIL readings
Stays lit = Data link circuit malfunction
Causes = Short circuit in data link connector or
Faulty ECM or
Short circuit in data link connector wire.
That's straight out of the manual.
I would clear all codes to make sure you're starting fresh with no old codes.
Then with the kickstand down, try again.
Last bike I saw do that had the killswitch set to off.
I don't have sound right now so couldn't hear it. Just throwing it out there :)
Faulty ECM or
I do it with the kickstand up and down and the result was the same, But thanks. I have the manual but it says that if the MIL stays lit, the engine operates normally and mine dont even start.
1 - 12 of 12 Posts
