1 - 10 of 10 Posts
i bought a salvaged 05 because I enjoy my 06 so much it ran fine but needed a new radiator so i bought a used one and replaced it know when i start it up the pgm-fi indicator light flashes 3 slow 4 fast to my understanding this is a code of thirty four.....but whats that mean? and why did replacing the radiator set it off?:huh: i replace a bunch of other stuff two but i started the bike after all that and it was fine. then did the radiator and cooling fan. started it back up and the problem started. checked for leaks and I changed the radiator cap to see if mabee the new one was damaged seting of the ect sensor or something but not knowing how to reset it did me no good this is giving me a head ache since my first problem was it wouldnt start after after replaceing the head light come to realize i put the tipover switch backon upside down:rant:
In checking the Honda manual, a code 34 refers to the servo that operates the cables that go to your valve in your exhaust. Check the electrical plug and connection at that servo. Also maybe go over any other connectors you had apart doing the work. You know what they say. Go where you had your hands last. The manual is available on this forum somewhere and you can get more info there. Hope this helps.
Dennis
Dennis
thanks Dennis
would u by chance know were the servo's were located or this manual might be cause I'm new to this forum...... I havent done any work to the tail section of this bike yet still has stock exhaust. all the work I've done so far is purely cosmetic body, turn singnals, headlight, footpegs, forks, radiator and clutch side clipon full replacement.
Sorry, the manual is not on this forum and I don't want to get into copyright crap and because of its size I can't send it but the servo motor is located just behind the cylinders and you can't miss the 2 cables coming from it going to the exhaust valve just before the muffler. Since you haven't been in that area be sure to check where you were working. How about the ECM (computer) being located next to the rad. Anyways here is a good link with pictures that may help you with your mods.
Honda CBR1000RR Tech
Good Luck,
Dennis
Good Luck,
Dennis
After looking at the picture on the site u gave me I see that the other end of the cables frome the exaust valve goe to just above the cluch bleeder nipple maybe when i blead the cluch i did something i'll have to check thanks for u'r input
ok i realized that i dont even have to start the engine for the indicator to go of and after the fuel injection stops after turning the key i here a wine from the survo and the pully moves slightly and the indicator starts flashing im confused i also see were their is a posible third line at the very bottom of the pully to hook up is this for a different model and non existant or could this be my problem that it may have snaped any info would be much aprichated Im gonna order a survise manual but it will take time to get it and I'd like to fix the problem as soon as posible
P.s I did here a unusual loud pop the first time I turn the key before the problem started
nope there is only two cables hooked to the servo
it should reset back to normal when you turn the key
try unhooking the battery to clear the code
worse case you get a light
it wont hurt performance
Chapter 6-32 in the manual. EGCV potentiometer malfunction. Looks like five tests to look for opens or shorts. Start reseating connectors and wigglin wires. Check all your fuses. Oh and an unusual loud pop when turning the key is a bad thing.
1 - 10 of 10 Posts
