Banned
Well I have a c&s extended swing arm on my 01 929. The problem is the mount for my caliper bracket the slider bar that holds it in place on the swing arm is not there, so the mount just swings. Is there any solution for this problem.
I'd suggest contacting the manufacturer as they would clearly have encountered such a thing before.
You could use many different means of connecting the caliper back to the swingarm including simply welding a new bar to the extensions.
Banned
Ok called c&s they said 25 to weld or bolt on the piece I need. And they are only 35 mins away good times. Thanx
