1 - 19 of 19 Posts
Hi Guys,
Yesterday when I stopped the bike and turned off the ignition there was a pop noise and smoke came up from the front of the bike. I looked around and couldn't spot anything - when I started her up again she ran fine??
This morning I spotted an oil leak from here - what is this and any ideas why it's leaking from here? Also do my headers look ok? Worried as to what this is and how it relates to the pop noise and the smoke I had yesterday.
Cheers
Alex
Hi Guys,
Cheers
Alex
That is the cam sensor.
The "pop" usually points to the valve cover gasket blowing - are you sure it's not just dripping from there after running down from the valve cover?
Check that the crankcase breather is not blocked.
It has also been associated with the stator blowing so it'd be worth checking the charging system is working.
Cheers for the quick reply mate - it could well be running down from the valve cover - assuming i'll have to take some of the fairing off to get a good enough view of where it could be leaking from the valve cover?
Where can I find the crankcase breather please? As for the stator - i'll get a multimeter on her tonight and see if she is charging. As for replacing the stator will I need to drain the oil when removing the stator cover? Will looking at the stator provide any clues as to whether it is knackered or not?
Cheers
One other thing - if it is the stator which after reading around other theads i'm 99% certain it must be - I was also getting a flickering of the lights recently.
Will I have to replace the valve cover gasket or can I just push it back in per say?
Cheers
Cheers
Breather comes off the valve cover on the 929.
Lean the bike against a wall and you will lose very little oil when doing the stator. If the gasket has been glued on you will probably want to replace it.
Visual inspection _might_ see a fried stator, but simply putting a multimeter on it is a _lot_ quicker, easier and probably cheaper.
Great thanks - i'll check the breather first. As for the multimeter test I take it I just do the ordinary test of the charging system and note voltage?
Not too bothered about loosing oil actually as I could do with doing an oil change at the same time anyway.
Btw is this the thing I would need to replace? http://www.bbbikeshop.co.uk/acatalog/info_1073.html
I'm a bit confused about the stator/alternator terminology - I take it the stator is just part of the alternator and you have to replace the whole lot??
Cheers
Oh and can I get to the breather with just removing the fairing or do I need to remove tank etc etc?
Btw is this the thing I would need to replace? BB Bikeshop Ltd G89 Alternator
Cheers
That link is to a stator.
The stator is the static part of the alternator, the rotor is the rotating part of the alternator.
If a component has failed generally you only need replace that, but it is possible for it to damage other components - that's why you test all the components.
You would probably prop the tank and remove the airbox to reach the breather and the valve cover.
Since you are removing the valve cover it would be sensible to measure the valve clearances while you're in there.
Ok thanks - I guess i'll have to remove all the airbox gubbins including funnels etc? I do need to change the plugs so at least that will happen at the same time! Think you have to entirely remove the tank on the 929 to do that too :thumbd:
Will test first to see if it's obviously the stator as I've read on another thread someone was able to push the valve cover gasket back in - that's if it's even come out??
So...just done some tests on the stator and here are the results. I tested first with the battery off and stator unplugged from regulator (Haynes manual said so) and the again with battery connected. I didn't bother to do a check of the charging system or with the bike running as i'm 99% certain the stator is fecked.
Basically testing across the 3 pins I could never get a consistent reading - it would jump initially to perhaps 17 and then come down before I would loose the reading entirely and it would just be blank. Think the lowest I got was 0.56 and the highest was around 16 or 17.
Then I tried the ground test and I could never get a reading from that?
Finally I did the same testing across the pins with the battery connected and that was the same - jumping around before going flat or negative and then to no reading.
Does this confirm that the stator is toast before I pull the cover??
Cheers
Discussion Starter #12 (Edited)
Ok so after removing the stator cover because I couldn't get a resistance reading I then realised i'd had the multimeter on the wrong setting the whole time! and am now getting a consistent reading of 0.03 ohms across all pins/phases.
And on inspection, the stator looks completely fine (see below pic). What do you guys think - look ok to you?
Annoying i've removed the cover but it was leaking oil from down there recently (think I fitted my R&G cover without a washer on the right bolt) so replacing the gasket isn't a bad thing.
But what could it be now?!
I have just had a thought though....on inspection I can't see any oil making it's way down from up near the valve cover and in the haynes manual it says that the cam position sensor (cam pulse generator) has an o ring on it - could it simply be a knackered o ring here just slowly leaking oil past it???
Going to whip out the sensor and see but to me it now seems obvious!
What else could the pop and smoke be?
Cheers
Banned
What is the spec, not 0.03 ohms? What range are you on now? It looks like a short from the base(ground) to the coils, and the coils are nicely cooked black.
Take a whiff, does it smell burnt too?
Discussion Starter #14 (Edited)
Haynes says anything from 0 to 1 ohms - any other tests I can do with the bike off to confirm whether or not it is the stator?? Will take a whiff and see if it smells burnt. Will also try measuring stator pins to ground and see what readings I get.
Cheers
Discussion Starter #15
Ok so tested the stator over and over again this morning and I get consistent readings of 0.3 or 0.4 ohms across the pins/phases. And i've done the ground check and it doesn't appear grounded - it also doesn't smell burnt.
Fair to say the stator is OK?
Now to figure out what else couldn't caused that pop and smoke?? I've checked the o ring on the cam sensor and it seems fine but i'm going to replace it anyway just to be sure.
Discussion Starter #16
BUMP - any more ideas please?
I do still need to check the crankcase breather which will take me a while as I need to take tank/airbox etc off.
Just ride it, it's fair to say it wasn't anything terminal. Keep an eye on the engine case for leaks, apart from that, relax.
Discussion Starter #18
Right guys - took the tank and airbox off this weekend to have a further gander.
First of all where is the crankcase breather in the below pic? Is it the one that comes out on the left side of the valve cover? It doesn't seem blocked but i'll remove it and check.
Also i've noticed some staining around the valve cover but it doesn't appear to be leaking - see pic below.
Finally I removed the plugs as i'm going to change them while i've got it all apart and most of them had oily residue around the base of the plug?! Does this confirm some kind of valve cover leak?
What do you think?
Cheers
Banned
I had a ST1300 with a shaft seal leak I never fixed because of the hassle removing the swing arm. Leaks are part of the joys of ownership, like tip over scars, zip ties, flat black rattle-can paint jobs, bent levers, jiggling the key in a worn out ignition switch, etc. Start it, if it's not pouring out after a ride, live with it. If you can't, that's what craigslist is for.
You would really get a rash if you owned an old Harley. :rotfl: You'd also get arthritis in both hands and lose a filling or two.
1 - 19 of 19 Posts
