1 - 11 of 11 Posts
Help anybody with an Akrapovic Race exhaust for a 954. I recently sourced a supposed full system but seem to be missing some bits so Im after some help with are the springs near the head the same as the spring down lower and does anyone have any pics available of how it looks at the head. Any help is greatly appreciated
This is mine.
As best I can recall all the springs are the same.
I just helped BLouder with his, as i remember, all the springs were the same. We had to handle every section a couple times because of fitment problems, I don't remember any of the springs being different.
on my RRX system all the springs are the same. ive 2 springs in the kitchen 3 yrs now, never put them back on, and no issues.
Thanks for that. Ive ordered the springs and now the next problem with this system is the canister is 370mm o.d but the clamp is around 400mm. Does anybody know what carbon clamp will fit a 370mm o.d canister
OD is outside diameter, you appear to be measuring the circumference?
Akrapovic exhaust people, can anybody help with the collars that bolt to the head do you still use the metal oring gaskets from Honda or something else. Any help greatly appreciated
Yes, you still need the flange gaskets.
1 - 11 of 11 Posts
