Help please,
While the bike is warming the revs increase to aprox. 2000 and when is supposed to decrease to aprox: 1200 it increases to 5000 and it stays there. If I stop the engine and I leave it for about 7-10 min. it is fine when I start it again the revs are 1200 rpm
Is there a damaged sensor or something?
Help please,
On the back of your throttle bodies, there is something called a wax unit.
This device controls your idle circuit and is dependent on coolant temperature.
You can inspect it by pulling it out, checking for damage to the spring or the o-rings used to seal it.
*a service manual would really help out during this procedure.
Thank you! One of the tubes from the vax unit vas stuck! So much mud from the cooling liquid!
