1 - 13 of 13 Posts
I have a problem which is gonna cost me money.
Ok, I have a 2002 954, and I remember the manual saying something like 26,400KM when I get the valves adjusted.
I remember a long time ago like at 13,000km or less I could hear a ticking noise on the bike , like a car ticks when its old (valves I guessed)
The bike only does this when its cold. I let it warm up, and it went away.
Now it has gotten louder at 29,000km and it won't go away untill I rev the bike at say 7 grand for a while and then quiets down..
It ticks really loud when cold.... like theres play between the valve and the cam.
I brought it into my dealer I bought the bike from a few times to show them the noise it makes but every time I bring it in the bike is warm and they can't hear it, finally one day I let it sit for like 45 min or something and started it and it slightly ticked enough for them to hear it but they figured it was just the valves needed to be done.
Well at 29,000km I took the bike in to get the valves done and they took the top off and said my valves are fine, no need to adjust em, cam looks great...
my bike is 5 months off warrenty. They don't know what the ticking noise is. They phoned Honda and are waiting for a call tommorow to see if honda will allow warrenty the labor to take it apart to see whats up. If not I have to pay..
Valves are great, the bike ticks really fricken loud. Any ideas?
I read another post on here that a guys got a tick (like me) but it only comes on when the bike is warm. where as mine goes away when the bike is warm..
When you rev the bike up, the tick gets faster....
at 60$ an hour it would be expencive to have them open the motor up any help would be great...
By the way, bike runs great normally (When its warm) I have a hindle muffler and a PC3r with the erion map on it.
Oh one other thing, when you rev the bike up when it ticks there is alot of black smoke (unburnt fuel i am guessing) and a little blue as well (oil burning?)
But that all goes away when the bike is warm.. No more black smoke and no blue smoke.
Also when I ride around town and deaccelerate (once tick is gone and its warm) THere is no blue smoke or anything so I dont think its the rings.
I heard something about noisy injectors. any chance? help!!
Darrell262 : I have a problem which is gonna cost me money.
If the valves are within specs but the noise is related to rpm and only when cold, it could be piston slap. But that would be so unusual for Honda that I'd say it's unlikely.
I have the same ting on my ’02 954RR. At 15.000 km the engine ‘ticks’ quite heavily when cold. It stops once the temperature reaches around 60 degrees Celsius.
I contacted the dealer, but they just said I shouldn’t worry about it…
Ok Update guys.
I got the bike back. 29300km on the bike.
They said the valves are in sync, no need to adjust them.
They said my cam chain is tight, and that the cam looks new.
I have always used their honda oil ither GN4 or the HP4 stuff.
So I still get this ticking when the bike is cold. ticking like valves making noise. The ticking is in the upper half of the motor. They said my bike is over the warrenty, but they phoned Honda and honda has agreed to pay for the fix as long as its their parts that malfunctioned.
If they deem it rider abuse, I have to pay for labor and everything (whole cost), but I don't have much choice cause the noise bothers me, its can be heard by the other guys riding when we are at a light etc...
The noise when warm is still there (I can hear it) but not very loud.
I just talked to another friend who bought a 2003 954, and he as 3500km on it..
His bike is starting to make the same noise as my bike has for a long time. just quieter then mine.
Oh and my friend jay who owns a 2003 600rr says his is starting to tick a tiny bit..
What gives..
I am sure I'll get them to tak it apart and I'll get stuck with $60/h labour and it wont be covered. Rider abuse I am sure they will say.
Piston slap probley.. I took a look at my old plugs and they look fine, some carbon (slight) build up on the side of the tip of the plug, but they are blackish/brownish.
The honda dealer in town has no clue what the noise is, and they said that honda canada has no clue to what it could be as well.
I run 91 octane gas Esso or Chevron which hasto my knowledge no or very little oxygenated gas or methenalhol
CanyonCarver : Small exhaust leak?  They tend to go away as the bike heats and metal expands to tighten up the leak.
Just a thought...
Canyon Carvers advice get's my vote as well! You should at least check the manifold nuts. A small exhaust leak can sound VERY metallic like if it's close to the valve/combustionchamber..
Yeup I thought I had something wrong with my clutch - used a stethescope and it sounded loudest there, but it turned out to be a leak on the #4 exhaust port.  A lot of wasted time in disassembly, troubleshooting, but hey...I am glad its something simple and nothing detrimental.
Good luck with your search, but check here first.
Ok, right on I'll check the bike for an exaust leak.
Never really though about that.
Bike still runs great, just the tick. :)
My bike has always had that cold tick.  From the first day started.  It still sounds like a chainsaw with only 4g miles. It is a 2002 954 with only PCIII and never beaten up.
An easy check for exhuast leaks is to put your hand over the muffler end at idle. You'll hear if it's leaking.
From what I read, I'd guess an exhaust leak too, but your dealer should've easily found that.
When the dealer took a look at your valve clearances, did they inspect the cam lobe height? I checked mine after 41,900 miles and some of my exhaust cam lobes were worn down as much as .030' below the service limit spelled out in the service manual. I don't think this would cause ticking like you're describing, but it might help to get them to cover it as a warranty issue.
Keep in mind that the 929/954 have titanium valves that seat on stainless seats, which are inserted into an aluminum head. These metals expand at very different rates. It's my belief that's why the valves tick when cold.
1 - 13 of 13 Posts
