1 - 2 of 2 Posts
this is kind of a repost..I'm wondering which PCIII map you're all using for your bolt-on's.
Has anyone popped for a custom map with just a bolt-on? Was it money well spent in your opinion? Can you really 'feel' a difference?
I also have a question. It's based on the assumption that DynoJet makes their canned maps that appear on their website at their facility in Vegas (2000+ ft. above sea level) on an actual Honda CBRwhateverRR. Here's the question.
If Vegas air as it flows through a given contraption's air intake system is Power Commanded to mix at a 13.XX:1 air/fuel ratio with a given fuel, would 2000 ft. elevation air require less fuel than if the same exercise were duplicated at a 150 ft.above sea level altitude using comparatively 'rich' or oxygen laden air on the same contraption using the same fuel?
If this is indeed the case can the 'button tune' method be used to richen the map proportionately across the board to compensate for altitude differential?
Can the button tune method be used to further compensate proportionately across the board for an a/f mixture that is too lean or rich. For example, I believe Dan Kyle and others recommend a 12.7 or thereabouts a/f ratio and I believe most people use 13.something unless asked to do differently; and I believe Dyno Jet is in the 13.xx:1 camp.
This is getting long enough to lose an audience. I'll stop here, now.
BW
i sprung for a map. have the hindle bolt on and flapper mod. i was using the jardine map before and generated ~131hp. after map was still generating ~131hp. smoothed out the power curve a little bit. looking at the map they mostly removed gas. i am still waiting on a call back on the af ratio they adjusted for since i forgot to ask while i was there.
my opinion, take the money and buy a full hindle system and just use the map on the web. you'll surely get more hp out of it. and then if you want to spend the money on the map, it'll be much more worth it.
i will probably get a full hindle and a new map as welll (custom maps on the same bike are half priced at the place i went after the first one) eventually. will post up then too.
hope that helps =)
1 - 2 of 2 Posts
