1 - 13 of 13 Posts
ok I have an o1 929rr and I had couple of problems with it but today I was cleaning out my the headers . I dismounted them from the motor underneath the bike were the headers and exhaust pipe meet there is like a lil motor with what it looks like connected to the servo motor ....and when I start it up sounds lil rough someone told me that I have to adjust something with the idle cuz the gas its not burning right..... cuz it smells like gas fumes coming out of the exhaust ...........SOMEONE PLEASE HELP
Hi.
I too am having starting problems on my 929rr. It was flashing a code for a while and then whiped all data off key. Reprogrammed and worked for 10 days. Now again won't start. Seems data is off key again!
Ok, let me go back right to the start of this: for about 2 months I thought there was a problem with "overheating" cause once I rode the bike stopped and tried restarting it wouldn't prime for at least 10 minutes. Almost like it had to cool down before it would start. I then thought its my fuel pump and I had it replaced. But no such luck. I then took it to a bike shop which checked everthing and said everthing is 100% and I had to go back to the guys who helped me when I lost my keys 3 years prior , cause they think the data has been wiped off my key.
I then called the key people whom said I can bring it in, but its impossible for data to be wiped off a key. Yet when I took it in he said I was right the key was dateless. So he reprogrammed it. And I had my bike back, but only for 10 days (however for this 10 days it was flashing 3 short 3 long) and I am back with no starting bike. Please could someone help?
Your talking about the H-VIX Exhaust valve, it may need adjusting after you disturbed it.
Download a manual or buy one.
Hi.
Perhaps i should start my own thread? How do I do that?
How many flashes do you get?, I can look it up in my manual.
Thank you I just downloaded the manual another thing now I crank the bike on it starts up pretty good but then after like 10-15 Seconds of being on the FI light indicator comes on (it does not flash stays on ) then the bike just starts to bug out and turn off WTF
When you say turns off, you mean the bike cuts out but all the lights stay on?.
Banned
Hi.
Aint - Fuel pump pressure-to crank sensor-to seeing if a muffler disconnect shuts the bike off and Jay knows that answer. I would think key on, key off, the servo motor defaults to a timed static to punch mark on the cable's bell crank? Something like that. So is that back in position, either key on or key off but not running?
Mr.K = It's not a fuel pump if it runs for 10 days. This is crank or cam sensor related-to ECU having a code present. Or say it narrows down to the ECU. No crank or cam sensor is going to keep running for 10 days, have heat thrown at it and heat is the breakdown of a sensor usually. So the thought is, eliminate crank/cam for it starts up once key is turned back on is it? So the crank and cam start cold, start back up hot, but a key off to reset everything? = ECU... you'd assume.
Only a blinking light and a count as to who is throwing the code knows for sure.
The pleasures of trying to diagnose a fault over the internet :).
Also could be a crappy transponder in the key, that doesn't hold the information long.
Hi everbody.
Pls could someone tell me where I can get my hands on my CBR 929RR Wiring diagram?
Thank you
Jaco Pienaar
I just want to thank everyone for the help !!!!!!
One last thing anyone know where I can get a hold of a manual for a 03 kawasaki zx9r?
Discussion Starter #13
Ok i am here again i just took off the yoshi pipe that came with my honda 929 put on a slip on pipe tip ....and i been riding my bike like that but its been feeling very jerky like if the fuel or air gets cut off bake and again starts to flow anyone knows why is that please help
1 - 13 of 13 Posts
