1 - 20 of 23 Posts
Just to add...
AJ04 will need a HISS ECU & corresponding HISS Chip (or maybe the complete set including lockset and keys)
i have a ecu and the full wiring harness to go with it what is a hiss and hiss chip
It's the immobiliser that's built into the ECU on non-US bikes.
qoute me a price, and would it be possible for you to ship the merchandise to India.
I take it that it comes with a key? The HISS chip is a small transponder chip which lies beneath the shiny side of the key (theres a Honda logo on that side)
No key necessary, these are the US model harness and computer
The ignition switch is different though and I don't know if you can wire a HISS ignition switch into the US harness. It's probably doable.
Ahh fair enough - thought you had a HISS ECU.
Hmm true say, would have to check the plugs...
how do I find out it will work on my bike. will a photo help?
You really need to find out which market your bike was built for and get a wiring harness for it to determine whether anything electrical is compatible.
Did you find out the market letter after the SC50?
Discussion Starter #15
the chassis no. is SC501000xxx, that's it. all the stickers are in japanese.
If i open it up will, the ecu reveal anything?
SC501 is the US Californian model. Definately wouldn't have HISS.
No, I wouldn't suggest cutting the ECU open.
Does the ECU have the 19 and 17-pin connectors or two 18-pin connectors?
Discussion Starter #17
I meant to take the ecu out and check part no., pin connectors or something
i will try and find out about the connectors.
You'll want the 49 state harness and CDI I have, the california components are more restrictive and lose power
I don't think that's correct. The Cali model does use an O2 sensor for fueling but I'm not aware that it's any lower on power.
1 - 20 of 23 Posts
