Hi just brought 900rr v 1997
I assume been stored for year or more fires but wont idle at all
I stiped carbs cleaned . also need small o rings that go on the pilot jets.
wheres good place get carb kit from i found one mentioned 900rr 98 sc 33
is that okay for mine.
I puting back toghter had low side crash the guy brought of his freind.
So put most body work back on got front fairing plasic welded
Also hose from top cv carbs to air box filter was missing.
And little plasic box has no filter in it , do replace the whole plastic box
and ideas where can source one aftermarket ?
The sub air filter can be sourced separately but I just cut up a piece of dish washing sponge for it, better than nothing.
Pretty sure the carbs only changed in terms of the jets used? You can compare part numbers on an online fiche.
If those o rings are ripped or not sealing you could get too much air bein bled in which would stop it idling well. Replace and see where you're at.
yeah am sure some where missing well okay i loose things. yes
was thinking cuting up old foam filter doing that.
Moneys in short supply these days.
Thanks buddy appricated , yes i order the kit.
