After changing a bunch of parts in the last couple of months, fork lowers, throttle wax unit, cush drive, sprocket, fuel pressure regulator, brake pads etc, I still have one tiny what seems to be an electrical glitch to be solved. Notice the sound at 0.11 and 0.39 in the below video:
Out of nowhere the power cuts off for a fraction of a second and is then back on.
To try and counter this I changed the spark plugs a month ago,
But the glitch remains.
Thinking could be a kaput ignition coil? The power delivery between 1200 - 2000 rpm is edgy, some engine lash in all gears, but it works perfectly fine past 2100 rpm, so I end up feeding some extra clutch till I'm in the 2000 + rpm zone.
