So there are no FI lights when the bike starts up or ever but I went to read the old history of codes. It kept going and going and so I decided to just clear them and see what pops up after I go to work and back tomorrow. What I can say for certain is codes 7, 8, 9 (ETC TP IAT sensors) but also I am pretty sure there was codes like 13, 14, 15 etc on the injectors (dont remember which ones but it may have been all of them or a couple), and I know there was also either 18 or 19 or both (cam pulse, ignition pulse).
I keep meaning to bring this up, but the previous owner did some funny business to the wires going to the ECU (pictured above). As far as I know these are all the cables going to the injectors. I was looking at the color codes and all the pink/green pink/blue pink/whatever were all injectors. Idk if they used something other than a power commander in the past or what they did. One of the cables goes to speedo also. I have no idea. But the little clamps lets you plug something in and take it out.
I am wondering if the hiccup and the fault codes related to the injectors are happening when for whatever reason one of those cables going to the injectors gets a bad connection? I am guessing they tried starting the bike with all the sensors disconnected at one point or who knows what for all the other fault codes, which is why I am being dismissive of them. But I could be wrong. I have started the bike a couple times for a few moments, and so far no new fault codes.
I am considering just taking them out now and re-soldering the cables but I am leaning more towards the idea of letting it play out tomorrow and seeing what happens first. Theres not a lot of cable to work with to fix is what is annoying about it.
The bike runs fine in every way except for the dim right tail light (intermittent), and the hiccup at idle (also intermittent) with a mild taste of bog in low rpm but I can chaulk this up to the simple fact that it no longer has the exhaust valve and needs a tune. The bike screams once you get going. I checked a couple plugs the other day and they looked good, but I should probably check all of them.
